From what I could gather, it sounds like the TPS was 5% out before the PC installation??? It's measured in voltage and without the PC, I would like to know how he arrived at 5%
He had the bike on the dyno and put on some sensors hooked to the dyno. It showed the throttle position for idle at 5 or 5%.
The throttle stop screw which is capped on your bike is the only way to adjust the TPS in the stock configuration and unless the cap on it was removed, it's difficult to understand how it could be out as it's non adjustable by the TPS unit itself.
When the stealership put the throttle sensor on I guess it was adjusted by them wrong, at least as I understand it. I also was wondering how it originally got out of adjustment to cause the problem in the 1st place. That is why I posted this and was asked if anybody could find anything wrong with what the wrench told me or the dealership.
The PC can take care of adjusting the TPS to zero.
