dolt
Well-Known Member
The OP says "starter is chattering fast" whatever that means but did not indicate if motor is turning over. It takes spark and fuel, so one or both are missing. Suggest that the OP drain the tank and refill with fresh fuel and replace the battery. Even if the battery tests OK on a load test, put back in the bike and subjected to actual load, it could fail again; cut to the chase and start out with fresh fuel and fully charged battery.
