free website stats program bogging, need more power | Page 2 | Harley Davidson Forums
Thanks Glider. I do have question about the petcock. There is a mesh pc inserted in Tank where the fuel line is inserted. There are two places wher the line could go. Does this have anything to do with the reserve?
The lower one of the two is the reserve feed for the gas, if you use that one when you run out of gas, you will have no reserve to run on.
I guess I will just remove the carb and pull the float bowl off and clean it wnd spray out the carb with some good carb cleaner. How much will a carb rebuild kit cost?
Can't help with part numbers or prices but you shouldn't need anything but a screwdriver to R&R the float bowl.
