cowboywildbill
Thanks for that it was a cool show. If I remember correctly water flow friction loss is the factor that eat's up water psi. "from the water bouncing and rubbing along the insides of pipes turns. Also head psi. roughly .434 psi per one foot of elevation, which is why they pump water up into water tanks. A 100' high tank yeilds about 50 psi at the ground level. I guess the smoother you make water the better it will flow.
Any way I'm waiting for someone to come up with a can of twincam cam chain tensioner wearpad restore. Just pour it in the oil and it recoats and restores the orange nylon wear pads in your engine. Should sell for about 9.99 per can.
Remember graphite oil? I used that stuff and it wiped a cam in one of my smallblocks. Wasn't there a product called tornado and wind tunnel like the X-wing?
I'm not knocking the X-wing, but if it was that good why wouldn't they incorporate it into an intake design?
