free website stats program Brake Lines | Page 3 | Harley Davidson Forums
Brake Lines
Thanks for getting back to me. I believe the MC stays where it is with this kit. So what I need to do is extend the plunger rod 2" then all will be well. Is there any body out there that sells extended plunger rods they you know of.?
Guy; After looking at the diagram in post #15, it looks like your master cylinder is mounted in front of your brake pedal, not behind it. If this is correct, you need a shorter brake rod if you move the pedal forward. Maybe I'm wrong, again.
I will go back and look at post 15 and see, But after looking at my bkie the Master Cylinder is behind the brake pedal. Thanks anyway. Do you know where a guy might find a longer plunger rod.?
