Hey Toby, is there room enough for a sleeve in the middle of the swing arm? It seems you have the skill, I would try to find new box tube and just rebuild the rear end part. Cut the arm, sleeve the new rear part to the old front with new holes in the back. You would have new welds on all 4 sides of the joint. And the heat stress would not be a factor where holes for the axle are.Th esleeve would only need to be about 2 inches with an inch or so supported inside.
As far as the heat stress worries. If you weld slow with the proper heat settings and dont go crazy the effects should be minimal.
Matt
Matt
