No true believers in the "Tooth Fairy" here I guess, so don't expect a dime under you pillow for your trouble anytime soon...! :small3d029:
Checked on the bike today. My dealer replaced the entire clutch and the gear on the starter under warranty. They also did the SE Compensator install for 1 hr labor. The broken teeth were not attached to the stator so I'm pretty sure they were attached to the magnetic drain plug when I had the 1K, 5K, 10K or 15K mile service done. Not sure how I feel about that....I can't point fingers but sure would like to know where those gears went.
Yes it appears that there is a problem with the teeth on the ring gear breaking. I have a 2007 ultra with almost 40,000 miles on it. My warranty is out on bike, and I have had numerous ongoing problems with the bike( starter-crank sensor-fuel pump line). I approached the service manager at my Harley Dealer. He contacted Harley directly and Harley has agreed to pay for the parts post warranty. I will pick up about $220 in labor. FYI...There ia also a flaw in the fuel pump line located in the gas tank on some models . It was designed too long an rubs on the inside of the tank and a hole develops. For a long time everyone denied the problem too me but when I purchase the new line it was designd shorter "imagine that". Recently a harely mechanic admitted to me that it is a common problem and they replace about one every month. Should have been a recall item.Sunday, I attempted to install my SE Compensator and Aim VPC clutch. After I removed the stock compensator (a flimsy piece of junk) I pulled the primary chain and noticed three bad teeth (all in a row) on the starter ring gear. One tooth is completely gone, the next is 1/2 gone and the third tooth is chipped....none of the broken teeth are in my primary. The teeth are probably attached to the stator. My dealer is going to pick the bike up Friday to take a look at it. A very reliable source said that in '09 there were some hardening problems at the factory and this is not an unusual problem.
Last year I put 15K+ miles on the '09 Ultra. It has a 103" motor and 255 cams all of last years riding season. I never had any starting problems or grinding issues when starting.
Anyone else seen this? I'm hoping the my dealer changes the clutch basket and the starter under warranty.
Just something I thought you might want to look for when you have the primary cover or the derby cover off.
