RibEye
Senior Member
How does the system keep the pump primed, or prime it when it has dried? It seems to me that once pressure has been obtained, there should be oil held above the pump, in the lines to and from the filter. Is it possible, that normally, this oil can't drain past/through the pump when working right, but can drain past/through the pump if hot and there is a problem? If so, maybe the pump is not seated right or has developed such a problem. Is there a way to see what is accumulating in the sump, before starting? Even so, I have never had a problem getting oil pressure after a full drain-out, so how does the pump get primed in the case of initially dry?
I'm just thinking...
Enjoy,
Rich P
Enjoy,
Rich P
