wolfshead1
Heavy foot figure 35% drop,light foot 22% drop pullin.Height means less mpg,lighter is better.
I've been doing some reading and thinking about this recently.
The travel trailer guys worry about aerodynamics a lot. But, not just the nose of the trailer. A vee nose trailer will help somewhat but there are two other areas that really affect the aerodynamics of the trailer quite lot. The bottom of the trailer and the back end.
Ideally you would want a completely smooth bottom. No frame members or even axles to catch the wind goind underneath. Some of the travel trailer manufacturers and trying to fix this problem.
The back end of the trailer is a huge problem. Your vee nose might part the airflow nicely but when the air gets to the back of the trailer you end up with a large low pressure area that actually creates a suction. This suction slows you down quite a bit. The faster you go, the worse the suction gets.
A vee nose can actually create a suction along the sides of the trailer. It's not as bad as the tail but it does exist.
I conclude from what these other guys have figured out that the ideal trailer shape would be a giant lozenge. A rounded nose with completely smooth sides, top and bottom, followed by a rounded tail. They are talking about the kind of rounded nose found on a nuclear submarine. The tail would be identical to that. One of them was even trying to put fairings around the wheels and tires.
I'm using a landscape type trailer. I don't get that large low pressure area behind the trailer. Of course, there's no protection for the bike on the trailer either. I'd like to add a rock guard to the front but I just haven't found the right thing yet.
