Chopper
Senior Member
johnnyreb, spend the money for the tool's, the case has a thin lip that the inner cam bearings press up against, if you chip that lip trying to get it out thats a case and 3 tons more work & money. The outer cam bearings just press out of the cam plate using a press. Pressing the inner bearing back in you want them to go in stright with out shaving any thing off the side walls and to proper depth.Hey just wondering about the bearing pullers. Are there any way to get these inner and outer cam shaft bearings out with spending a fortune on the pullers? I have an 2004 ultra with the big bore kit installed new when i purchased in 04. I have 75,000 and the oil pressure started bouncing around. Thanks to this web site pretty sure of whats wrong. Just tackled the stator, wasn't bad at all thanks to this website! any feed back would be greatly appreciated.
bill-h, if your wife's bike is stock you will save your self a lot of work if you cut the stock push rods out and go back up with adjustable, saves tearing the top end down.
