What are you looking at replacing them with? The HD Hyd unit or the S&S gear drive, or something else? and what are you basing your choice on? I have over 50K on mine and am looking to replace after ridding season. thinking of the S&S unit but would like to consider all choices.
I just bought a 2005 SEEG2 Laborday weekend and was told about the cam chain tensioners as my bike has 28K miles. I checked them last nite and they both looked almost new. You seem to hear about the problem bikes but not to much about the problem free ones. I'll probably check them every 20K or so but they look like they could go 100K easy, if the current wear is any indicator. I was mentally ready to spend $1000 to convert to the hydraulic upgrade but I'll invest in more chrome instead. Getting a look at the inside tensioner was harder than I thought and the mirror gave me a marginal view. I used a small alan wrench to feel for any wear ridges to verify the lack of wear. I hope yours is like mine!
Not sure if the 05 is much different than the 01 but I would change out all of the cam bearings since the cams and support plates are out of the motor
I found the site below with details on how to do it without the use of a press, I tried it and it not that hard, i got the HD cam service kit and it came with all of the bearings and gaskets needed for the job I tossed the HD inner and used Tottington though, I removed the top end so I didn't need adjustable rods.
HarleyHogs Cam Bearing Install
Does any one have tools to do conversion that I could rent? I'm close to London Ont. Thanks
