danthern
Morning Gents,
In order to rule out the cams as the source of an engine noise I want to do a swap of the 255s that are currently installed with another set of the same. The bearings and tensioners have recently been replaced when the oil pump was replaced. I just want to pull out the old, in with the new. What do I need to consider? I assume that I don't need the 100 dollar tool that pulls the bearings since I'm not changing them. The main points seem to be the base circle and lining up the dots. I'm fairly handy with wrenches and have been through the top several times but the cams are uncharted territory. Any help or direction to links pertaining to this topic would be greatly appreciated. Thanks in advance,
Dan
Dan
