Bodeen: This seems to be the same plate as used on 2007 up. And yes, the upgrades are dream material, unfortunately my wallet wakes me up!
BigAl66: Any issues so far from re-use of lifters? the ones on mine have only 18K on them. And yes, I have planned on using adjustable pushrods. I too, share the same ideal on being able to do this with help and advice, as $ is tight these days. I plan on starting this project at the end of this month, and I would like to take you up on the tool offer when that time comes.
01rk: Did you use roller chains on both sides or one roller and a reuse of the morse chain on the inner?
Jennmarr: This is what brought me to the question of why was the roller/taper bearings deleted in place of plain bearing, and why would the SE plate still retain the roller/taper bearing. I know the SE stuff is supposed to be the "better" stuff, so wasn't sure if it was an actual thing or just marketing by HD. I have seen a plate with bronze bushings on all three holes, black in colour. And if the plain bearing on aluminum is good, why still the bronze bushing on the crank hole. Questions like this is what made me start this thread.
And I would also like to extend a big thank you to all who have responded thus far on this thread, the information has made it much easier to understand.
