dolt
Well-Known Member
UPDATE: Alive She Cried!
All went pretty well. The backlash on the cam gears was about .0005 and installed all I kept thinking is that it felt like a swiss watch movement. The outer gears had a backlash of .0005, .0006, .001 & .0006. So I was feeling pretty good/lucky with the fitment. By the way the Andrews gear kit were S&S gears.
While adjusting the pushrods, the lifters bled down fast. I didn't need to wait more than a couple minutes before I could work on the next one. Maybe because they were new..? (S&S 33-5350)
I'm not sure if this is the correct way but I left the plugs out attached to the wires and grounded the plugs, then three 5 to 10 second turn overs to attempt to prime the new oil pump and start to get some oil upstairs before I fired up the motor. AGAIN I'm not sure about this procedure. Maybe someone will inject some wisdom here.
Anyway she started right up and sounded GOOD!
I still need to install the EJK 3 (Dillion @ Doebeck recomened the 3.0 vs the 3.5 for my set up, I can also bypass the 3.0 by just disconnecting the ground wire which I liked).
Well I need to wait for spring for a test drive but anticipating all good.
I'll give another update then.
And I appreciate everbodies help & input here. It's a great feeling to know someones got your back when you are doing some of this stuff for the first time!
Glad to hear all is well. FYI, gears may be packaged by S&S but Andrews manufactures all gear sets for cam drives.
