Let us know the outcome with the prices.
Ordered the kit from Tri-County H-D this AM, everything I wanted came to about $430 including shipping. Seems real reasonable to me, the local stealership wanted a whole lot more.
IT's not that I don't want to use the SE plate, just want to know if there are any issues with them.
Seems the person who marketed the Herko kit is no longer taking any orders.
Thanks Glider for the info, the prices at Tri-County look pretty good.
Did you order the spacers and cam service kit as well? If you plan on using adjustable push rods you wont need the full cam service kit as it includes rocker gaskets and an improved breather (metal instead of plastic). However, if you are taking the pushrods out the top like I did you might consider purchasing it. It has all the gaskets, O-rings, and bearings that you will need to get the job done. In my opinion it was easier to order the kit and have everything I needed then to forget something and have to run to the dealer in the middle of my project. The cam kit is very complete.
Yes, I also ordered the adjustable pushrods, forgot them the first time I called, had a senior moment. They were another $116. I already have the bearings, and o rings just need the gasket.
Thanks for asking though.
And a good torque wrench:s
I may as well ask my dumb question. I have a 2009 dyna low rider. does that mean I already have hydrolic timing chain tensioners on my motor?
