This a bolt in cam option for your consideration
Cam specs
Intake Open: 17.5 BTDC
Intake Close: 39.5 ABDC
Intake Duration: 237 @ .053
Intake Lift: .561
Just remember WAY to the RIGHT 0f 30* MANDATES more than a cam change... If you ONLY want a cam change you HAVE to go LEFT for the Power.
39.5 degrees is a Lot...
The 551 cam closes at 19* that is on the LEFT side of 30*
Your statement is incorrect
Intake close isnt the only spec that dictates the level of compression. This cam I showed has a different centerline on both the intake and exhaust. Changing the spread of the lobes allows a lower lift and longer duration which is both quiet and easier on the valve train while still making broad torque over a wider rpm range.
End result is with a good tune this cam will show a increase in torque and be easier to tune.
