BUBBIE
Well-Known Member
consider the S&S 511 gear cam.for the 103 reason no shoes to wear out.
brownfoxx1,
I used to think the same way here. Thinking Gear was the way to go...
(still do IF you do crank-work, weld and plug with timken bearings install in the cases while apart.)
Then the PROBLEM.... HD Cranks that have too much Out of alignment, and ON bikes right off the show room floor. Not all but quite a few do OR the possibility of Them getting out of alignment IS a BIG problem. Needing to be with-in a couple of .000 to do a gear drive, THEN HD saying that the tolerances for the crank are OK at ,004/.006 :swoon
I RE-Thought my thinking and decided to SUGGEST with the new style Hydraulics as a Keeper on todays TC bikes.
The New style of tensioner also didn't show much wear against the chains for many miles... I Don't Doubt IF my 09 FLHR bike would not go a full 100,000 before needing to replace the New style tensioners.
If I'm going to do a Gear Drive cam set-up, I would want the "FULL Treatment" of Plug and Weld with timken case bearings installed for proper support of the crank:newsmile093:
THEN I would SUGGEST Gear Drives:newsmile011:
Good Stuff...
