danthern
Hello to all...hope you can help me figure out this maddening noise on my 09 Road King Classic. Has the Screamin Eagle 103 Upgrade, about 47K. I've had it since 16K, ridden from Alabama to British Columbia, West Coast, etc. Been a great bike. Just recently she started with a sound that is most like a chirp from a cricket. It seems to be impossible to pinpoint where it's coming from. First I thought the primary, perhaps from the front end, no, maybe the right side....you get the picture. The dealer couldn't help. Their best recommendation was the Compensator but he admitted that he wasn't sure. It does it cold or hot and only when it's under a load. The noise stops when I release the throttle and is back with the slightest twist of the wrist. I installed the new SE Compensator kit, replaced the rubber bushings in the exhaust brackets, have checked every fastener that I can think of. The drive belt is within specs...I did check the forums here before this post. I know that noises can be unique but I hope that with these symptoms someone can point me in the way I need to go next. Thanks in advance!
