J
Jack Klarich
Guest
I think that the belt is fine as far as the tension goes. The dealer had the rear tire off maybe 5000 miles ago for new rubber so it was adjusted then. What's the best way to clean the belt and pulleys? Does the inner primary have to come off? Thanks for your tips!!
Does the chirping happen all day long? More after it has rained? If so the tension on the belt and or dirty belt comes to mind, you can jack up the back end, in neutral use an old soft tooth brush and mild dish soap and water scrub the belt and watch for nicks and wear on the pulleys
