Big Rol
Gotta admit, an extended warranty is looking better all the time.
5 bills just for a belt...man-O-man.
You mean an extended warranty would cover the belt or just if you proved it was a defective belt?
It may be the pictures or my eyes but your belt looks to be only about 3/4" inch wide. How wide is your belt?
And if there is a bend in the flange, would that account for the wear only extending along a 10" span of the belt? I guess if the rotation of the wheel consistently strikes only the same area of the belt with each go-around.
Trying to get a flat belt to track perfectly down a pulley requires almost perfection in parts. I would guess most belts hug one side of a pulley or the other. There are just too many variables involved. It would be Great to have it ride true and center but I think that happens only with few cases.
I am curious to see what others say about their belt tracking.
Bubbie, How do you get the belt to track perfect and at the same time keep your rear wheel tracking perfect to center line of frame.?
I adjusted my rear wheel/tire to track perfect with center line of frame. At that point can I change belt tracking without affecting wheel position? I thought there was not much you can do to change it.
a lot depends on HOW LUCKY you were on the draw........ frame straight and perfectly true. wheel and tire aligned with the belt..
