J
Jack Klarich
Guest
That condenser serves two purposes, it causes abrupt change to when iginition point opens and closes in conjunction with coil (supresses spurious "ringing oscillation") for stronger single spark and protects the points from arcing damage. And yes, one of the symptoms of failure is high speed miss or intermittant miss. Points and condenser was in transition in the 80's (for motorcycles)...cages had already migrated towards electronic ignition systems.
Points and condensors were a bit better than H D first try at electronic ignition and you could change the points and condensor pretty easy and parts were available every where:s
