My float level was measuring 21.5mm-the manual states 18.5mm.i adjusted the tang accordingly.is that enough to cause flood issues? the float needle and seat i inspected thoroughly-the rubber tip was hard yet somewhat flexible with no grooves or indentations on the needle-and the seat was fine as well-jets are clean as a whistle and bouyancy tested the floats in water-no leaks.Sooo-can i go with the incorrect float height? man,i really dont wanna reinstall and take this dude apart AGAIN LOL!
At that height then the fuel will be about into the overflow and start running out
