free website stats program CB Output/Receive Range | Page 2 | Harley Davidson Forums
should at least get 10 miles on a matched antenna:D
With a max of 5w and a nearly perfectly tuned antenna, (1.1:1 swr) you may get 5 miles range at best. If there is any traffic on the channel your broadcasting on, it will be considerably less. Since there is no "ground plane" on a bike for reflectivity of your signal, you are relying on the base loaded coil in the antenna to make up for the lack of this ground plane. I would say that your best case scenario under these conditions would be about 2 miles. :s
