CDN- Chromeplater did the prep work inclusive in the price. Totalled about 130.00 including shipping. I used Brown's plating out of Kentucky. They did a real nice job. The switch was a standard 3 blade connector type. It is the FL Softail switch. picked it up at J&P Cycle for about 35.00, half the HD part.
Kept the original ignition as a fork lock.
JJ- Not real difficult on the ignition switch relocation. But it is time consuming to do it right and carefully. First decision is whether you want to use a stock dash and drill the hole(drill press is highly recommended) or purchase the Screaming Eagle dash. The SE comes with the hole for the ignition and is chromed from the factory. Looking back, I would have taken the SE route over using a stock dash. Wiring is straight forward but the ignition cables need to be extended to reach the new postion. If you go with a stock dash a mounting plate is necessary for the new ignition switch. I have some pictures of how it was done and part numbers and can provide you with greater detail and some swearing saving tips if you decide to go forward. Let me know if you want more detail. Finally, to give credit where due, I got the procedure from a member on another forum and refined it a bit.
