Hoople
Account Removed
The picture has no negative return for the regulator. If the bike wiring is the actual picture, there would be no charging current and the battery would not get charged.
I would install my own 10AWG pigtail jumper wire from the case od the regultor to the ENGINE block.(not the frame) You can not trust the frame. I would go to the engine/transmission assembly.
Also double check that CB breaker for any voltage drop across it while the breaker is passing a good amount of current. I am not saying that is your problem, but I would replace it with a Maxi Fuse/Holder and Maxi Fuse. Those CB breakers were OK years ago but today there is so much better.
