I went to the tech page AGAIN and tested the stator and rectifier. The stator is just a little short of the minimum vdc per 1000 rpm. I put a negative mutimeter probe on ground and tested each prong of the two prong plug to the stator. One showed zero volts and the other showed at 20 vdc a reading of .2 volts. I have ordered a new rotor and i think I may add a new rectifier to that order. The stator shows infinity from one plug to its mating one but Zero ohms to ground. I also put in a new circuit breaker today just in case. So when all the stuff I ordered comes in every thing will have been replaced at least twice. I have a feeling it is a combination of the two that gives me erratic readings. Fossil
