Set your powertrain so the swingarm pivot is horizontal when the steering neck is vertical (side-to-side). That is, 90° between the axes when looking from the front or rear. In conjunction with this, you want to ensure the rear axle is completely parallel to the swingarm pivot and have the centerline of the rear tire to pass through the centerline of the steering neck. You also want the front tire centerline to pass through.
Be aware that when you change the front link to work on the front-to-back alignment you'll also change the vertical alignment. You need to walk both the front and top links in tandem.
I think my '07 touring shop manual spec'd something like a 3/16" band running front to rear that the tires should track within.
If you've ensured proper physical alignment and you still get a "lead" (pull) to either side, it's time to strap on some lead weight and/or pack your bags accordingly.
You can swing your rear tire toward the direction of lead, throwing your wheels out of alignment, and mitigate the lead. But this makes the bike dog-track, and when you don't have the wheels/steering-neck in proper alignment you open a whole 'nother can of handling worms.
I'm confident that the majority of the problems "solved" by True-Trac, &c. installations could (should?) have been addressed with a comprehensive alignment.
