Well I went thru the self help area but didn't find anything similar to what I had.
I followed all the instructions on how to enter the diagnostic session and retrieve the codes. Like someone else mentioned, I had the engine light come on for the customary time then go off, waited about 4 seconds, came back on for 6 seconds then went off. From what I have been reading this indicates that the engine light has come on because something was wrong. After the light went out it didn't come back on. I waited for another minute or so and it still failed to blink. I removed the jumper and put everything back together. I then removed the speed sensor, cleaned it off, and replaced it. I haven't ridden it since but will in the morning, hopefully it has solved the problem. Going to check the battery voltage in a few minutes, hopefully that isn't a problem, had it replaced a few months back.
Thank you,
Jeff
Thank you,
Jeff
