DON'T make a Big Deal out of this adjustment.. IF DONE EXACTLY LIKE SAID it will be right...........
Sorry for all the caps BUT this is a VERY IMPORTANT adjustment and so often done Wrong ... AND IF done WRONG will cause Damage.....
YOU have it RIGHT..... SLOW down and DO IT Just like said......
The clutch handle SHOULD Grab Just where you said it DID after your adjustment........ at 1/2 turn out is the Best (my book) to open clutch plates and 3/4 of a turn Out MAX(like Smitty likes)...
The BEFORE you adjusted SHOWED You IT was TOO LOOSE of a clutch adjustment...Hard to shift (clutch rubbing its plates together and not Loose enough)...
Do you remember HOW much you turned it in to start with????..... This is VERY important to Notice when you adjust a clutch....
Most Don't LOOK before they adjust and Should.. Then you will know IF the clutch WAS way out...and yours probably WAS...
Now Note,,,,,,
Way out on the clutch handle is where I keep mine.... 1/2 turn IS what I use and YES IT takes time to get used to it....
the critical part of YOURS Now is DO you have 1/16 to 1/8 Open play at the handle lever at the cable???
IF yes it is good... Try it here and in time You will get used to the adjustment...
Smitty says HE Uses 3/4 of a turn OUT from FINGER tight against the clutch...
HIS clutch grabs FURTHER IN closer to the handlebar>>>>> HIS adjustment ends up IN CLOSER than yours at the position it grabs..... SO IF you adjust the clutch at 3/4 turn OUT from clutch (I use 1/2 and NO MORE than 3/4) IT will grab CLOSER to the handlebar....
This is what you are trying to do: get the clutch plates separated ENOUGH to shift easily BUT NOT slip when fully out...
Think here and see the further OUT the clutch grabs,,, at 1/2 turn out the EASIER on the shifting and easier on the clutch...easier to find Neutral...(1/2 turn out on clutch pack = Min out,,,,3//4 = Max out)
BUT if LESS than a 1/2 turn out It may cause the clutch to SLIP and do damage....SO the adjustment is CRITICAL......
Now you got it.....
again sorry for all the caps but this is VERY IMPORTANT to get RIGHT.....
