cdn-bigfoot
Junior Member
Did you change the clutch cable at all? Sounds like too short a free play in the cable.
sorry about the silence glider. last night sudenly I could not connect with the web site hd talking don't know what happened. I as far as i can tell I did the adjustment bt the book. I have done this adjustment many times on several bikes and never had this problem. This is the first time I have done it on this bike. When I first loosened the lock nut I had to back the center allen screw out about a half turn before it didn't touch.Then I performed the adjustment just as the book said. turned it in till it touched and started moving the handle out from the handle bar. Then backed it off 1/2 turn and tightened the lock nut. Then readusted the the cable till there was about 1/8 inch space at the cable and the pivot. Now the handle will only pull back about half way before it gets real tight like it has bottomed something out and I am stretching the cable.
Jack, The OP readjusted the clutch and all is OK now
