If your clutch looks like the one in the PDF that HDDon put up in post #15 then do this.
Loosen the clutch cable slack all the way, adjuster is near the middle of the frame down tubes at the front of the motor. Undo the locking tabs on the 4 nuts on the clutch hub and remove the nuts. Remove the spring retainer, diaphragm spring and the pressure plate. They just slide out.After that you can see the clutch plates. They also just slide out, you may need a pic or small screw driver to get the plates out . Keep them in the order you took them out. There are 2,I believe, pieces that have OUT stamped on them. I think they are the pressure plate and spring retainer. Be sure to put them back correctly. If you read the PDF it explains how to install it.
tourbox
