OTRA
Update on my clutch issues. I checked the cable as best I could and it seemed OK, so I fabricated a clutch spring tool and disassembled the clutch. All but 3 of the little brass rivets had come loose on the center spring and caused the problem. Fortunately the clutch hub was not damaged and I will be replacing the plates, friction discs and the center spring. Thanks again for all your help
