M MAD BRAD Member Aug 30, 2009 #11 sounds like some good advice i also lube the clutch cable when doing a adjustment buy the one with the needle works great, mad brad
NEWHD74FAN Experienced Member Retired Moderators Aug 30, 2009 #12 glider said: Has to be to the bottom of the clutch basket with the bike upright and level. Click to expand... Deuce, from what you said, when looking at Glider' pix if the fluid is clear yellow/amber (not brown) you are good...you may have been a little low if you were on the side stand and fluid did not drip over...:s
