And I do yours. This is just plain old Great brain food if you ask me.
Now in all fairness do I feel that Techron really works? You BET I do. I have NO doubt it will help keep combustion chambers cleaner and will also keep my injectors clean of deposits.
Do I also feel that Lipitor will help lower my Cholesterol? Once again, you BET I do. Dropped a friends level from 280 to 175 in just 5 weeks.
But the problem in both cases is the side effects can be worse than what your trying to fix.
Just two of the bad side effects of Techron (as stated by Chevron themselves) is that:
1) Some WILL get past the rings and into your oil. It WILL have a negative effect on the lubricating properties of oil. It does not easily out-gas from the oil upon seeing higher temps. Yes, even with Mobil 1.
2) The elevated combustion temperatures from it's use can ruin exhaust valve seats.
Those are some spooky side effects and just may not be worth the risk....
I would rather live with the carbon deposits.
But that is the beauty of America. We have freedom to choose.
