I too have the SE compensator installed. Yes the SE compensator has much larger & stronger washers but it really is designed to be USED with high output engines. Lets face it. How much compression of the SE washers can a person expect using a stock production engine? Without the power absorbtion of the compensator washers, doing damage to the crank is very high. My guess is using an SE compenstor on a stock 96 output engine would be like running pure direct drive (no comp at all).
I have, use and like my SE comp but in the back of my mind I wonder how much drive train absorbtion is taking place.
I have the strobes and Hi speed film to record a comp under actual working conditions but I don't have the ability to load the engine or else I would test it..
So are you saying that installing the SE compensator might actually cause long term damage to a stock TC96? What about a TC96 with a simple Stage I?
