You can disnonnect the small wire from the starter and use a jump wire for battery power from the main power wire on the starter this way you won't have spark or added fuel to the cylinder.
Plugs are out and grounded so no spark. If fuel is a concern, pull the fuse to the circuit that powers the fuel pump but I would not be concerned about fuel during a compression test.
NP if others can learn , I'm all for it.@Fisherking, sorry about derailing your thread. I just wanted to get a few others opinion on the results of the compression test I did right after buying this scooter.
