Had an Andrews EV27 cam fitted and Dyno tuned again and it came up with 65.33 HP and 71.67 of Torque. I would have thought that with all the work it would have put out a bit more. Any suggestions?
Cheers.
:cheers :AUSTRALIA
1. 200ccp is way to high for a stock bore/stroke 1340 motor; something isn't right.
2. I still question your tuners capability.
I have attached a chart for a stock bore/stroke 1340 motor, not head work, static CR at 8.5:1 with a set of EV46 cams, stock head pipes, HD slipons, timing set at 32*BTDC, stock Keihin CV carb, SE 6000 street module iginition and SE dual fire coil; pretty plain Jane configuration. Note the better numbers and the flat torque curve.
