Woods brothers make them but besides the advertizement I haven't heard anything about them. I installed the s&s Gear drive. Works great but gets a little noisy when good a warm.
I think at the time they were not in business 5 years ago ;-) cheer.
Ken,
Contacted Herko, and got all set up.
But I have a question for you. Did you use adjustable pushrods or did you pull the tops and the rockers to get the one piece rods out? If you used adjustable rods, did you replace the pushrod tubes/covers with ones that extend down lower so they are easier to push up out of the way to adjust the rods? If you did, where did you get them, and what is the part number.
Hello TQ,
I'm new to this forum but I have an 03 Road King that I noticed was sounding a bit unusual last year so put it away a little early. From my investigation, I have a feeling the cam chain tensioner is failing so my quest this spring, before I get her on the road, is to handle that problem. I had a grand idea to go to gear drive but I have no idea what my runout is and don't want to purchase two systems in case I'm out more than the allowance. I noticed your thread when searching the web and thought you might be able to help me out. The guy that Kemo referred you to for parts necessary to make the conversion to hydraulic chain tensioner which would include the conversion plate, etc. Since I'm in there I'm going to replace the cam and bearings with the Andrews 21 or 26 (still undecided). I'm not a high speed high revving guy but like to have torque and power when I pull out to pass without downshifting. I would appreciate it if you could send me the guy's name or contact where I can obtain these parts. Oh, is the higher capacity oil pump included in the package? Thanks so much for your help sir!
Hawger03
Hawger03,
As Stray Dog said above, Herko (John Wadsworth) is no longer assembling his Roller Chain Conversion Kit. Andrews Products still has one as does HD and some of the third-party makers like Fueling.
The AP kit looks like this:
Andrew's Products Harley Davidson Cam Conversion Kit | Hot Bike
or
http://www.andrewsproducts.com/images/2013catalog/Andrews_Products_Motorcycle_2013.pdf (see pg. 5)
Check out the pictorial I did when I upgraded my '03 Ultra (r.i.p.):
TQ's Engine Build
Harley Davidson Forums
Let us know how you do. And take lots of pix!!
Cheers,
TQ,
For some reason that I dont remember, I didnt think the Andrews kit 288902 for 2002-2006 TC was still available. I could be wrong tho. I just tried calling but it was too late in the day.
May not be, but that is from the 2013 AP Motorcycle Catalog. Hope it is, or there is another source of kits lost!!
