wannaride
Re: corvett air shocks on touring bikes
You don't cut anything on the bike. You can modify or replace the bushings in the lower shock mount. Without having the shock non modified (mine were already done with the stock bushings) I can not tell you exactly what needs to be done, but I think you cut the sleeve so the shock fits closer to the mount on the bike. The air is ride height, I have not noticed much difference when I have it aired up, but I am sure it may affect it some what. I have not noticed any ill effects, are there better systems out there? Yes I am sure there is. But as far as better than stock, I believe they are better. But my Ultra had maybe 75K miles so who knows who good the shocks were to begin with. For the money, ability to raise & lower the bike at will and the ride, it's worth doing. As for adding a compressor, you don't have to. You can go to any station and put air into them. You can get by cheap by getting the shocks only, I ran the shocks like that til I got the compressor mounted. The compressor weighs in at 3#. You can go on a diet & loose that.
Toby
Toby
