free website stats program Cracked Exhaust Header | Page 2 | Harley Davidson Forums
Thanks all, just got back in town and it sounds as if this is indeed a relatively common problem that I'll have to keep an eye on....I think if there is a next time, I'll use the remove and weld route. :)
Thom
As Barndog said RH is well aware of the problem in the older rear headpipe, they will send you a new rear headpipe free of charge no exchange needed, I would call get the pipe let it sit till the problem happens again then change , the tab on the older stlye is wey to thin and directly welded to the headpipe and over time the tab would just vibrate off leaving you a nice crack in the headpipe, if I remember rite the new headpipe they sent me had a added flat plate welded to the headpipe and a heavier tab was used and welded to the flatplate giving a better bond that can withstand the vibration.
