A good friend of mine had that happen twice...
He went to Fullsac Performance - True Dual Headpipe Kits - Lake Havasu City, AZ and got that true dual kit and loved how it worked and has the problem solved permanently... )
If you shop around you can do it for $750 or a little less. I found these on ebay. V&H slip on muffler-item #14017648322=$337.95 and V&H true duel headers-item #310384804514=$370.79. Headers come with heat shields and all hardware.
It does not take long for a loose install in the rear, at the slip-ons, to take out the Y-pipe and its mount to the top of the starter. That mount is only a bent metal tab. If it breaks, you'll get a cracked Y-pipe. If your slip-on mount(s) slip loose (rubber out of holder), or the left saddlebag bracket breaks (common), in a few short minutes of riding you will have a broken bracket tab and cracked Y-pipe.
Good luck,
Rich P
You make an excellent point here Glimmerman. I work as a Mould Maker ( 41 yrs.) and we use cast iron blanks as a mould all the time. One of the problems that we frequently encounter is when the iron looses its life after many heat/cooling cycles while producing bottles and gets fire cracked. Welding it gets extremely difficult as there are many pin holes in the weld. We have to undercut the iron deep hoping to find a good base for the weld to adhere. We also use oxy/acet with a hopper on our torch that funnels nickel powder that fuses to the moulds as we weld. Nickel & cast iron are a great marriage.I'm a boilermaker/welder with 42 years experience. problem here is that the metal is a) contaminated with carbon from the exhaust. b) lost most resilisence because of repeated hot/cold cycles. my personal recommendation is oxy/acetylene welding with an S-6 wire. it will remove most impurities. S-3 is for mulitiple pass applications and depends on clean metal(not here). mig or tig tig welding has a concentrated heat that may warp the pipe. oxy/acet. will heat the entire pipe ensuring less warpage and better control of the heat affected zone. it may be necessary to post-weld treat the area. also, a good lpt (dye check) of the area may show additional cracking parallel to the visible crack. this should be addressed as well. don't be suprised if it cracks again. most likely the metal has lost it's life. just a problem w/ heat and age in an exhaust. jmho.
Could you explain the dye check process? I am curious about that.
Thanks,
HC[
Wow, you guys are way over my head......I'm just gonna try some JB Weld.
