What about Wheelies?The crank run out can show up in the 96 unmodded engines too. It depends on how you ride. Sudden missed downshifts to the wrong gear or doing burnouts will shift the flywheels.
TQ,
Thanks for the info. My problem is this. How much runout is too much and will cause damage to the oil pump? I would think if .005" will cause damage to the gear drive setup, it is still going to cause damage to the oil pump.
My bike has 35000 miles on it and it runs great and is smooth, but I am just wondering if I should go ahead and get a crank, already welded trued and balanced and just plan on doing the entire engine. I did speak to Andrews and they said .002" was the limit for the gear drive. But do I really want more than that causing other damage.
Just trying to think this through all of the way.
Has anyone checked and found no runout or are all Twin Cams doomed?
Eric
But I think if you are not having problems, it is WAY overkill to tear apart the engine "just to do it". That could introduce all sorts of other problems you may not now have.
I'm not considering ANY engine mods. Haven't even done pipes, TFI, or air cleaner upgrades. I simply don't want this issue creeping up on an unwarranted bike and taking out the oil pump and then the motor. If you were in my shoes, would you go through with the procedure to check the runout or just keep riding? Would you skip the inspection and just invest in an extended warranty?
Thanks - you know about a million times more than I do about motors so I truly value your opinion - and, of course, anyone else's who cares to contribute here.
Awesome. Thanks TQ.
Oh, one more thing - what's an INA inner roller bearing, what does it do, and what would you swap it out for? Sorry, three more things!
