HOLY DIVER
Junior Member
what was the mileage when your engine went south Jack?
27,200, no knocks ,ran good in fact I rode it to the dealer with the rod bearings knocked out of it and a cracked oil pump
wow thats funny my Deuce has 27,500 and i rode mine to the shop with a chewed up oil pump mine was also running fine and strong,now should we break our new motors in on full synthetic? or dino oil?i've never had a fresh motor lol never broke one in.i have always used mobil1 v-twin 20w-50 so i'm thinking i'll use the mobil1 to break it in and change it after 500 miles.what you thinking?
I agree with you here and have always used Dino oil for my break in and changed oil and filter @ 100 miles, 500 miles and 1,000 miles on all my bikes yet H D says thisRings will seat faster with conventional; don't know any builders that break in on synthetic. Dump oil after first 50-100 miles but not filter; change oil/filter at 500 miles and again at 1000 and if you want to run synthetic, the 1000 mile oil change is the time. The first 50-100 miles are the most important for ring seal; should be seated by then. Important to discuss the first 50-100 miles with builder. If those first miles can be rolled up on a dyno so load can be applied, the rings can be seated that way, AFR checked for a "break in" tune. JMHO.
Good info from Dolt & CAPITAL JACK. Thanks.
tourbox
:s Thank you for ALL you do here @ HDT, you have made a solid contribution to helping all the members and I for 1 respect your opinions and read your posts:s
Jack Klarich said:I agree with you here and have always used Dino oil for my break in and changed oil and filter @ 100 miles, 500 miles and 1,000 miles on all my bikes yet H D says this. Note the last sentence:
"Screamin' Eagle® Synthetic Motorcycle Lubricant - SAE 20W50
This formula is approved by Harley-Davidson for use in all stages of engine life and is not detrimental to the break-in stage of engines."
