I use the Adjures Beacon 2 brake lights and clear turn signal lights up front. And yes being they are Halogen, they are BRIGHT...I have had motorcylist comments that they like 'em and easy to see day or night. Think Projector lamps here. Thing is you have both on the one side which makes them "twice" as bright to use as single brake light.
The Reds are 35W, the Ambers 25W and the Clears 50W...divide Watts/Volts and that is how many Amps draw...the Halogens draw similar energy to the stockers only MUCH brighter. Try putting them in Series (daisy chain the wiring) rather than parallel and they should dim by 1/2. I did not check if the case is ground, if it is you have to insulate them to get them in series. Light and current draw is not necessarily "linear" as light is more logarithmic...i.e. twice the distance brightness is actually the square visually.
