pilsnerbuck
I have a set of these lamps and agree that there's nothing else quite like LEDs. I started with Kuryakyn but didn't believe the plastic lense would hold up over time, plus I didn't care for the beam it put out, so I switched to Daymakers. It's a bit to set up but once you're out on a dark road, you'll see where the upper limit is (a defined line between light and dark) and whether you're flashing oncoming traffic when you hit a bump. If you see your light hitting too high, just bump it down some. The most precarious position I've been into are sharp curves on mountain roads at night when there's NO ambient lighting. You HAVE to run on high beam or else some deer would be on your fender before you saw it.
I also had the moisture buildup in mine. After two years running them, I called HD, got a case reference number, and they said to take them back to my dealer and they would take care of me. After the parts manager verified my case number, he handed me two new boxes off the shelf, and said have a nice day. Talk about customer service! The case worker at HD said they should not fail and they will make it right with HD owners. I don't know if that would have been true with Kuryakyn.
What I'm interested in now is what it would take to have the aux lamps stay on when switching to high beam.
