Just my opinion: I notice that the death wobble only appears in Harleys with rubber-mounted engines, that is, the Road King and Dyna series. You don't hear of Fatboys with that problem. I think the frames as originally designed used the bolted engine to add rigidity. It is lack of rigidity (among other things, like trail) which causes the wobble. I believe when Harley started using rubber-mounted engines to compete with the Jap bike's smoothness, they did not redisign the frame to increase its rigidity independent of the engine assembly. When you add to that the factors of loading, wheel and tire problems, wind buffeting on windshields and fairings, maladjusted frames, worn bearings, bushings, etc., you increase the likelihood of high-speed or cornering wobble.
