gs34
Junior Member
Some fuzz on the magnet of the primary drain plug is normal no matter what oil you put in there.
It is the nature of the beast.
The primary is where all of the rotating stuff is that causes fuzz.
Chains mating with sprockets, clutch disks mating against their steel plates, compensator working back and forth as it loads and unloads.
Expect some fuzz......but don't expect any chunks, or large shavings of any type.
If you see any of that when you do your fluid srevice, better investigate and see where it's coming from.
