Any issues removing the 02 sensors?
Nope. I put everything back together the way it was. Went on a 280 mile ride day before yesterday and ran like a champ!!
I meant to say that I put the 02 sensors back in and have had no issues.
Oops,, I thought he meant removing cats & O2 sensors and leaving them out. My mistake.
Welcome aboard!! Are you happy with the results???I took my 2011 Street Glide Header off my bike and went down to a local welding shop. I asked them to cut the pipe in half where the Cat lives and then remove the Cat and weld it back up and Grind down the weld and buff. Cost me a 100 bucks. The guy said the cat came out easy on the muffler side, but he had to chisel it out of the engine side with a rattle gun.
by the way I'm newbie here, name is Jake and I ride a 2011 Street Glide Sedona Orange
Here is where it gets interesting!! If everything was stock before you operate(yuk,yuk), I am to believe everything will be ok. If you have a high flow a/c or different pipes or a tuner, a new"map" will be needed. The air flow out of the pipes is going to be so much greater that you have to fatten up the fuel into the motor. I am running a Vance and Hines Fuelpak and all I did was called them and they gave me a new map and it took all of three minutes to enter the new codes, and that was it. Depending on what tuner you plan on using, you,re best to check with their help desk!! Can't hurt to call your dealership and talk to a tech about running catless without making any changes to your ECM on a "stock" motor!! If you have any more questions, I'll be glad to answer to the best of my abilities....So I am still unclear as to one thing.........once it is all put back together, sensors installed, pipe installed etc...... Do you have to remap with a power commander or SE? Or does it run well just the way it is?
Thanks.
