Jdsmitty10
Sounds like you have a better plan now. Just a "heads up" incase you don't already know. Tire pressures that you are use to go out the window when using ME880's.. Depending on your size, it can be 44 to 48 psi when cold. Be absolutely sure to run the correct pressure. It is a must with those tires. Don't go by what the guy selling you the tires says or what the owners manual on your bike says. Read all the information Metzlers has printed and published about those tires. I personally would not mix (front/back) those tires with any other brand or model. I run them and love them..
Thanks for the heads up hoople. So your saying go with what the side of the tire says for pressure?
