maine-e-axe
Junior Member
To me unless you sit in stand still traffic alot or live in the deep south and your oil temp isn't over 265 degrees you DON'T need a oil cooler. Thick oil is alot harder on the oil pump and the rest of the engine than warm thinner oil. Think about trying to push 50 wt oil through a paper filter vs 20 wt oil through the same paper filter. If the oil cooler has a thermostat to let the oil warmup before it starts going to the cooler to keep the oil at or about 220 to 245 degrees is the only way I would run a oil cooler. And when you change the oil, you don't have all that oil left in the cooler. JMO
